New CoreBook X i9-13900HK CP tuning questions
Hello.
I have a few questions about the upcoming CoreBook X. Will the BIOS be unlocked, and will Intel XTU be supported? Certain settings in the BIOS can disable undervolting, and since the 13900HK is an unlocked CPU, undervolting is possible. I had good experiences with unlocked desktop and laptop Intel 13th gen CPUs, where undervolting can extend battery life, lower the CPU temperature, prolong boosting etc (so more performance…). A lot of benefits.
And my biggest question is: Any plans to bring the 7840HS to the CoreBook X? A better allrounder with better battery life and 2x the graphics performance in comparison to the 13900HK.
Factory did not send it us yet Corebook X i9 so its not that we can check it
about 7840HS not for the moment.
Thank you for the answer. Any release date?
Not know yet. In China things are not like in West. We cannot plan so much in advance as things change everyday, so release date will be said when its about time
One last question. Now that you work with Acer. Will the Acer software work on the Acer branded Chuwi laptops (like battery control to hold the charge at 80% etc.)? Service support for parts and repair? Thank you.
Send an email to support because they need to ask Tech that, is a very specific question
