No Sound from internal speakers but fine with earphones in audio out
Sound is good when using headphones, but nothing from internal speakers when headphones disconnected.
In zoom, no sound when testing speaker, and no input when testing microphone.
When headphones attached can hear sound and mic works.
Cheers Andy Cooke
After what actions did the problem arise? Did you change the operating system after the purchase? Did your system receive updates? Try installing drivers from here.[Ubook] [Official Version] Chuwi Ubook Windows, drivers, EC,download
Windows 10 is having update issues, with audio, there are many complaints in general with the latest update 2020, try to install these drivers:
https://www.tenforums.com/sound-audio/135259-latest-realtek-hd-audio-driver-version-2-a.html
version 64 bit, and we review. Best regards
Thanks, I’ll give it a go later and let you know. Cheers Andy
Same problem here (Ubook Pro N4100) upgraded to Windows 10 professionell. Click sounds, but works with headphones. Realtek drivers made no difference! No sound via speakers.
install Dolby Home Theatre v4 by Mat Kairos, youtube show, enable .increment volumne
