Hello! Has anyone expanded the RAM of your hero box pro? is it possible? I feel that 8GB is done little in 2023 ![]()
(sorry for the writing, I’m using translator)
Expand the RAM? No, because it’s soldered onto the board.
Maybe you can expand it if you are a very skilled with reballing, have the necessary chips and the BIOS is not locked to 8GB.
A much more easier way is to install a striped down version of Win 10(Like Atlas OS, takes around 700MB RAM) or 11(Tiny11, takes 2GB RAM).
