Hello; my serial is SLarBXGZ1H231002476; download OS for support Chuwi service; and drives file.
have errors on install. The problem is the location of install.wim. Solved it force the path in MAIN.CMD; now another error:
if EXIST C: \Scripts \TESTTOOL.zip (
call “” x C: \TESTTOOL.zip -oW:\ xcopy C: (Scripts\TESTTOOL\*.* w:\ /s /e /y
if 0 == 1 GOTO: FLASH_BIOS
goto : END
C: \images>copy C: \Scripts\Factory\** w:\Factory\ / cherkyi
File not found - * *
• File(s) copied
C: \images›if 4 NEQ 0 set ErrorInfo=“Fail to copy Factory folder to w:\”
C: \images>COLOR 4B
&& goto :error
C: \images>goto : EOF
But I don’t have any dir “Factory” at C:\Scripts\ on downloaded Chuwi install files!! Exits another download file for my model?
