LarkBox X Intel N100 Does not boot
Serial : SLarBXGZ1H231001148
Bought on Aliexpress on november 2023.
It stopped during internet surf and cannot start windows any more now.
When you turn it on, you are blocked on the bios page.
When you save and exit, in stay on the chuwi logo.
Doownlad the windows and drivers from here and install again . I tried your serial number and it works
Windows installation tutorial: windows installation system tutorial
Thank you but it doesn’t work for me. I have a disk 0 with a size of 0 and a disk 1 with a size of 28 Go. I don’t think it’s normal.
@manonegra222
It seems that there is a problem with Windows startup that needs to be repaired. You need to get a Windows bootable pen with the media creation tool (downloaded from their website) and boot from it. Once in the Windows installation menu go to troubleshoot, advanced, startup repair.
I don’t understand. I’m supposed to have a 512 g ssd. Is it dead or just unrecognized? What can I do? Am I out of the guarantee?
I already tried to install windows with a USB stick from windows website, but there is no disk where I can install it. It’s the same problem.
Did you follow the instructions i gave you?
Post pictures of what appears when you try to install
This is the screen with the chewi installation program.
And this is the screen with windows legacy installation.
@Jygo @ChuwiESnotactive
I have the same problem. I dont see any ssd on boot or in the bios. Has anyone found a solution?
@manonegra222
If you do not want to open the device, remove the SSD module and then reconnect it, it is very possible that it has become loose during transport.
