Larkbox x wont fully boot
My Chuwi Larkbox x some time ago started not booting and going to the bios menu i want to assume is what it is. i found out that its my ssd as windows when i load it onto a thumbdrive doesnt recognize any storage drivers i found out that something is wrong with the ssd but cant figure out what it is how do i fix this? ive tried like i said to reinstall windows and its not finding the ssd that is built in (i opened the mini pc and checked the ssd it looked fine no fried areas around the solders or anything like that) im at a loss cause it just boots and insta bios and no matter what startup setting i change it instantly goes back to bios to which i later found out was also because its not registering the ssd.. how do i fix this?
It might look fine on the outside, but the inside could be faulty.
If it’s the hard drive, you just need to replace it or remove it and test it in another computer.
