Hello, I have a LarkBox X - N100 mini PC. It won’t boot; it just gets stuck on the Chuwi.com logo. I tried to access the BIOS and I’m not sure if I changed any settings, as I can’t get back into the BIOS now. What can I do to get Windows to boot? The mini PC seems to be booting: it makes a sound and the fan starts up. I need some help. Thank you
You can press F12, which is for selecting the boot device and also gives you an option to enter the BIOS.
It could be a problem with the motherboard, memory, or hard drive.
You can create a Windows installation USB drive and repair Windows.
Search on Google for how to do it.
Continuando la discusión desde Mini PC LarkBox X - N100:Thanks, Bruzan. The problem I’m having is that I can’t access the BIOS with F12. My idea is to connect a USB drive with the Windows operating system and see if that works. Any ideas?
If you can’t boot with F12, you won’t be able to boot from USB.
Take it to a technician or a friend who knows about computers.
