Two of the rubber feet of my minibook X have fallen. I still have them but I’d like to know what kind of adhesive could be used to stick them back on.
Thank you.
Thank you.
Same here. I used a tiny bit of superglue.
Cheers, Jaap
Yeah I used superglue too but they came off again eventually anyway. I lost two of them somewhere.
You can just buy replacements from ebay or aliexpress and glue them on again. Not sure if these specific ones fit but just as an example:
https://www.aliexpress.com/item/1005006071694235.html
Thank you guys for the information. Do you know what the composition is of this superglue product? We don’t have it with that name in my country.
It is a gel that contains ethyl cyanoacrylate.
Jaap
i use rubber pads and cellotape outer coat as glue doesnt work tried all types exce[t evo-stik because you need to get in there to unscrew the bottom which is why Chuwi made such crappy adhesive. A big embarassment to Chuwi for the rubber feet missing issue amnd for the easily scratched aluminium, and failing usb portts which are also not even explained in the manuals
