Hello
I buy anhi12 almost everything works well but i got a problem with the sd slot in windows 10 it recognise wih yellow triangle wow can i fixed please? In androd says empty sd card the if i format android reboot 4 times iè that it says dowload aplication and android home cames it says system dont answer please help thks
l have the same problem as here any help ?
The failure of the SD, both in Windows and Android, is known but does not have an effective solution, only temporary solutions and the problem is reproduced again. This problem occurred in all brands that used Atom processors. As it is a tablet from 2015, no updates have been implemented that can solve the problem
what is temporary solutions ??
about SD driver on other z83xx
https://theminixforum.com/index.php?threads/neo-z83-4-manually-install-the-driver.31/#post-5272
https://theminixforum.com/index.php?threads/neo-z83-4-manually-install-the-driver.31/page-3
which one can work ?? have anyone ever try it ??
