Hello everyone,
I just bought a Chuwi UBox with a Ryzen 5 6600H, 16GB DDR5 and a 512GB NVMe SSD.
I have a serious problem with power management:
• When I shut down (in Windows 11 and Ubuntu), the machine shuts down correctly (the power light turns off).
• But when I press the power button to turn it back on, the LED lights up but nothing happens: no display, no BIOS/GRUB, just a black screen.
• The only way to restart it is to physically unplug the power adapter and plug it back in. Then it boots normally and I can see GRUB/Windows booting.
This therefore does not seem to be linked to the operating system (same behavior under Windows and Linux). This looks like a BIOS/firmware or hardware issue.
Has anyone else with the UBox experienced the same problem?
Is there a BIOS update or workaround? Or should I just return the device under warranty?
Thanks in advance for any help
