I bought a Chuwi Ubox AMD Ryzen 5 7430U (SUbox0IZ1H250703069) and the website says this processor reaches boost speeds of up to 4.3 GHz, but it’s limited to 2.5 GHz. I couldn’t find the upgrade option or the option to update the BIOS. Could someone help me with this?
You can search on Google for information on how to speed up your processor.
You can install more memory.
Hi bruzan2025, how are you? Thanks for the tip. So, I’m looking for it and I found some tutorials but none have helped me so far. I found one for another Chuwi, but the setup is completely different, it’s a different BIOS version. For my case, I need the BIOS for the SUbox0IZ1H250703069 Model: CW1604. My biggest difficulty is finding it, otherwise I can manage.
The BIOS version you see is usually the reduced version.
To access the full BIOS version, search for a tutorial on Google.
I think it involves entering the BIOS, pressing F7, restarting the BIOS, and then entering the BIOS.
Be careful if you change any settings, you could mess everything up.
Be careful when overclocking
Yes, I haven’t tried that tutorial that says you need to enter the BIOS using F7 yet. I’ll try it when I get home and then give feedback here, but I’m still trying to find out what the latest BIOS version is for my MiniPC and I can’t find that information anywhere.
When I get home I’ll check the BIOS issue by pressing F7, but I’ll do thorough research before making any changes. Thanks for now.
Hi, thanks, I couldn’t get in here before, but I managed to access the advanced menu; I found a tutorial on YouTube. Once you’re in the setup (BIOS), just press Alt+F5. I managed to adjust a few things, but the processor comes from the factory with automatic overclocking.
