even though i downloaded the sf133k driver it cant find the driver.
please help
Check the properties this devices. Follow this instructions and checking the ID numbers here
still 2 unknown devices, when i search for the drivers i had no luck to install them.
broadcom driver, try to install it, but i always abort the process.
same here
May try snappy driver to identify for those 3 unknown devices
https://sdi-tool.org/download/
Looks a bit old school but does it job in those cases
Good luck
If you already changed the bios settings and doesn’t help nothing, then load the default settings in the bios and try again. I had already same problem and I reseted the bios.
Can you give a screenshot for the default setting?
you are a fucking magician… restored default settings in bios… and voila, now they’re GONE!
