Which USB C Hub Chuwi Surpad
Hello, i recently bought a usb c hub with hdmi, usb 3, rj45 port etc. to use this over the built in usb c connector of the surpad, but it doesnt work.
Which usb c hub is supported to use with surpad?
The specification of the surpads usb typ c connector should be qualified and support it??
Please let me know.
Hi, I’m using a VAVA model VA-UC017, using SD and TF reader all ok. Also the USB port all ok. I can’t test the HDMI port. BUT ONLY IF I REMOVE THE KEYBOARD!. With bult-in keyboard connected the USB-C it is only for charging.
Somebody know if this is the right operation?
