не могу найти драйвера для corebook x pro, нету звука , помогите пожалуйста
Hello
This is all the drivers of corebook xpro. I hope it can help you.
Thank you for your letter
thanks, i helped so much
Which of the driver helper you?
Hi Guys. I bout this nootbok CoreBook X Pro i5-8259u and had the same problem but i soleved that problem with sound by this driver
if you whoud like to send some money, the card is
5375414144548392
