A problem occurred while analyzing the package
Since resetting my tablet, I can no longer install certain apps, such as Insta360. Regardless of the app version, I get the message: “A problem occurred while analyzing the package.” Do you have any idea what the problem might be? My Android version is 8. The app was installed correctly before the reset.
The problem is that on Android 8, apps that were originally installed from the Play Store work, but the newer versions of those apps are not compatible.
Hello, yes, I tried installing the latest APK version for Android 7 and I still get the same error. I keep getting an error while parsing the package. On uptodown old version
What’s the power button color? Black or red?
The color of power button is Red
