just a click away from ordering a new Aerobook Plus 15.6" and now I noticed in some youtube reviews that the bezels are plastic. Is this true?
There is no glass from end to end like on Lapbook Pro? or Lapbook SE?
yeah, it’s pure plastic - matte around the screen and somewhat glossy on the bezel. the cover and the body are aluminium though.
If you haven’t bought it yet, here’s a con. Less than a month later, once again opening the laptop lid, I found that the matrix almost fell out. It turned out that the bezel does not have any latches, it is thin soft plastic set on glue. I had to remove the entire bezel, clean it from the remnants of the old glue and put it on a new one
