Model: HiPad X
Chipset: Unisoc T618
Serial Number: YHipaAEY20220703186
The build number I found on the tablet is Hipad x_yk_ us _20220630
Please can provide the correct firmware or rom to update to android 13 or above. the tablet is on android 11 and i cant update from the system settings.
i did, and this is what they send me
Thank you for your message.
Unfortunately, there are currently no updates available for this model.
Regards,
Chuwi Official Support
CHUWI Official Support Team from CHUWI INNOVATION LIMITED.
I thought there might be a way, that’s why I asked in this forum.
