Anyone successfully installed Linux Mint on Hi10 Air
My air is slow so trying to pt Linux mint on it - keeps hanging - anyone succeeded?
The Hi10 Air uses 32-bit UEFI firmware even though the CPU is 64-bit, so a standard 64-bit Mint ISO can hang before reaching the desktop. You’ll likely need to add 32-bit UEFI boot support to the USB or use a distro that ships it. Also disable Secure Boot and consider a lighter Mint edition, since Cinnamon may be heavy for 4 GB RAM.
Ok thanks - hanging is what i’ve got!
Thanks for the advice
