Hello Chuwi friends with problems,
I’m running Linux Mint on mu Gemibook pro CWI529, and I’m getting 2 maybe 2.5hrs of battery life.
Is there a way to exchange the old battery for a new one, and has someone done this before. Battery seems to be built in, so I need to take the laptop apart, I think.
And does anyone have a part no of address where to buy this replacement battery? Maybe even a step by step description of how to proceed?
Q256G21023460
12Gb memory
275GB HD
Intel Corporation GeminiLake [UHD Graphics 600]
Intel© Celeron© J4125 CPU @ 2.00GHz × 4
Sorry for the delay.
We have stock of the battery. You can buy from us.
Please do this:
You need to: Go to http://www.chuwi.com
Select your zone up corner right side(in this case Global)
Menu-Explore -Contact us- Aftersales Service
-Fill the form aftersales
-Dont forget to write INSIDE in the message:
Hello i was confirmed you have battery of Gemibook Pro in stock:
1-Serial Number /
2-Where are you from:
3-when did you buy it (i do not think is under warranty anymore, as our warranty is 1 year)
4-That you are willing to buy it. it will be sent from China.
*My colleagues answer in 48h and they will inform you the procedure.
Once you write please let me know, so i check that we received correctly.
Thanks for your answer, missing price in €uro, so I can decide If I want to buy because If it’s more than €40 incl fat, tools, and shipping cost it’s not worth it.
