I have CHUWI AeroBook 13.3 Inch
Intel Core M3 6Y30 14nm
Windows 10
8GB RAM
256GB SSD
AeroBook Serial: S256G19062414
Please, can send to me latest BIOS
Brankovic@msn.com
Best regards folks
Windows 10
8GB RAM
256GB SSD
Brankovic@msn.com
Best regards folks
Write to service@chuwi.com
Thank you
After I install new BIOS, and I founded that is USB port Tupe-C is deactivated by the new BIOS.
I activated USB Type-C port in BIOS, and USB Port-C still don’t work.
Hi
I update this EC, with “fix” what you sanded to me and problem is solved. The USB-C working.
Best regards from, Slobodan
I am very happy that everything works correctly. Enjoy your device
Hi
AeroBook 13.3 Inch, working excellent. I using laptop for business, because is light, and easy to carry around.
Best regards
I’ve the same isue. Could you send the fix?
BIOS Fix for Type-C port
Type-C port
http://uppit.com/5rul44buwmnj
Best regards
My chuwi Aerobook have the BIOS v 3.0.2 and I want to update the bios to the 3.0.6 (is the last version?) can someone provide me the update files?
thank you
Chuwi does not publish Bios updates but develops new Bios for new versions of the same laptop model.
Only post updates if errors need to be corrected.
You should check in service@chuwi.com if you are in this situation quoting your serial number
can someone please send me the link for the Type C port fix? Because link above is dead, thank you!
BIOS Fix for CHUWI AeroBook 13.3 Inch
I would recommend to contact with service@chuwi.com and make sure these files are suitable for you.
I need latest BIOS for BIOS for CHUWI AeroBook 13.3 Inch
Windows 10
8GB RAM
256GB SSD
I install Windows 11 Beta
It’s run OK bat slow…
Best regards folks
please can send me latest full compatibility bios aerobook intel core m laptop
