Bios hi10pro dual boot HQ64G42170107840
Hi please I need bios chuwi hi 10pro dual boot s/n HQ64G42170107840.thank you
That’s strange; it can happen when the update process is interrupted due to low battery.
Press and hold the power button for at least a minute, then plug it in to charge.
You can download the operating system and drivers from the Chuwi website, in the “Support” and “Downloads” sections.
or
You should contact Chuwi customer support: service@chuwi.com . for the BIOS.
It was after an interrupted windows update and after it does not turn on and not charge.
Now I have flashed various bios.Now the charge led is blinking and the tablet seems to turn on.
The lamp of the display turn on,but the screen remains black.
When the operating system crashes:
You can try resetting the boot sector
or
reinstalling the operating system
How can I do?
Above you’ll find instructions on how to download the files.
You can also search for a tutorial on Google.
