Hello, i read in several Forums that i can ask here to get the correct bios for this dualboot hi10 pro. I made all tests i can imagine. I can feel the heat from the cpu as i power it on, but i cant get any image.
C109S
So there is no existing Bios that i can reflash with my programmer?
thank you very much
can you upload it again? I need to reflash it again… dont know why it breaks itself if its not used for some time…
thank you very much
I need the bios for my Chuwi CWI529. Serial # is PQ64G42160902486
Thank you very much!
the fact that at the end of the serial number the numbers do not coincide a little, isn’t it scary?
It doesn’t matter, the main numbers are HQ64G421701
I will be much obliged if you can help me get the bios for my Chuwi CWI529. Serial # PQ64G42160804100
Thank you very much in advance.
BR,
Dan.
Is there anybody willing to help me, please, with the bios and images for my tablet?
PQ64G42160804100
Hello all, I have a HI10 HQ64G42180105508 that does not turn on after updating the bios. Can you send me bios file to write again?, thanks in advance.
Hello, i need bios for CHUWI HI10, serial is : PQ84G42161101539.
it’s c109s+, the c106 is not compatible, thanks
Hi please I need bios chuwi hi 10pro s/n HQ64G42170107840.thank you
What problem are you having with the tablet ?
