Bonjour
Depuis hier le bios apparaît en boucle et impossible de redémarrer windows.
Modèle gemibook pro
Série JGeBkPCY1H221000725.
Help !!!
i think you must reset the bios. you can search in english in this forum “reset bios” and see if you find the answer.
good luck!
Try To install first the software
Windows installation tutorial: windows installation system tutorial
