Hi, my charger is broken. I need a replacement. I bought it from Aliexpress. I have message them. @ChuwiESnotactive Maria tell them to reply my message? Thanks.
You mean replacement under warranty?
Else a standard 45 or more Watts usb c charger can be used. No need for the specific Chuwi charger.
Note that the minibook will not dissipate more than 35 Watts. A bigger charger than 45 Watts will not charge this laptop any faster.
Jaap
Yes, it is under warranty. Just one question, will a 12V 3.75A charger work? Or it has to be 15V 3A? Thanks.
Good question. I have not been able to test 12 and 15 volts. My chargers and power bank support 5/9/12/15/20 Volts. The Minibook always negotiates 20 Volts.
If ever I can get my hands on a 5/9/12 Volts power supply, I will test.
Cheers, Jaap
As Jaap explained you can buy another one. Or write to service@chuwi.com , when you do tell me and i will ask my colleague
