Broken USB-C port, no longer charging
After acting up a bit during charging, my son’s HiPad X’s USB C-port stopped working altogether. It seems that it needs replacement due to broken pins/soldering. Does anyone know where I could find such a replacement port?
I can find the following on AliExpress but I don’t know which one would be compatible?
I guess alternatively I could buy 24 different ones and see which one would fit?
Hello, same problem with that of my daughter.
I took apart and it’s a small part of the motherboard that broke …
The easiest solution would be to change the motherboard but I can’t find any.
Here it’s only the port itself that got disconnected from the mainboard PCB, the mainboard PCB itself is intact. So my situation is a bit better compared to yours it seems. Still not easy to find the exact same USB C connector it seems.
For what it’s worth, this seems to be the right connector (Number 6): 2PCS Micro Usb Jack Type C Connector Charging Charge Prot For CHUWI Hi9 Pro Android 8.0 4G LTE Tablet PC MT6797 X20 Deca Core|Connectors| - AliExpress
Which seems to be the same one as this one:
