HiPad Max USB Charging Port Replacement
Good day, my HiPad Max suddenly won’t charge whenever I plugged in the cable. I tried using different cable and charger but it still the same. I took it to the repair shop and they said it’s because of faulty charging port and it needs a replacement. So I need help to find a replacement for the usb charging port, like the type, serial, or any details are appreciated. Thank you.
  • Serial Number: JHipdMKK10220800592
  • Bought it from my country online store 2 years ago
Some time ago, we sent this to a customer that had similar problem
Maybe you can send this picture to the repair shop and ask them if with this would be enough.As they already know the issue with the tablet.
Thank you for the reply. If I want to find the replacement in Aliexpress, what kind/type of usb c port that I have to search for?
We have it in stock, you can buy from.
That’s good. How’s the procedure to buy it and I would like to know how much the shipping cost to my country?
