Windows don’t recognize the camera incorporated in my corebook x. Where I can find the drivers? there is another solution?
First we start the computer, and then click the start button in the lower left corner of the desktop to start the start menu interface.
Next, we need to click the pinion in the lower right corner of the Start menu, so that we can open the computer’s Settings menu.
Then we find the “Privacy” option in the Settings menu of the computer, so we enter the privacy Settings interface.
Finally, we just need to select the camera in the computer privacy Settings screen, and then adjust the camera permissions to on, so that it can be recognized.
Thanks for your response but it doesn’t work in my case.
Have you tried to uninstall the last update?
Settings>Update & security>Windows Update>Advanced option>View your update history>Uninstall update
1 ZCoreBDW1H230100739
2 Offline retail
3 2022-23 year
4 camera not working in manager devices descriptor error, not find needed driver for camera, cwi 575 help please
You can try to download this:
