Can i make my chuwi 10 x double boot machine_ cause win 10 sucks a lot mobile
i want to have both … win10 and android. is it possible on that machine/ hi10xq128gh620600853
question mark and thanks in advance
Not officially or supported, but yes possible. As in you can dual boot and try Android x86, though you may have varying degrees of success with things working or not and will have to be able to manually tinker drivers etc…or id recommend Chrome OS (I found it has better support for play store apps). If you want to get started there are plenty threads about it on both this forum and around the web.
the biggest problem in this froum - i dont know what model / serial number i should follow…
I think the only differences have been to do with the touch drivers and stylus… Either way if you try x86 Android or Chrome OS it is the same process regardless of serial number or model… Just don’t delete /override your windows…
For those of us who have a Chuwi 10 x with dual boot system, it is too bad that Microsoft’s latest operating system, Windows 10 is getting more and more hidden function. From the start, it has been clearly for the sake of their own products, against all rivals. Reason for this is simply because it no longer has any good function that can’t be replaced by competitors’ products. So why not try to use Android on your Chuwi 10 x system?
