Hello I unfortunately damaged the charger of my computer, it is therefore unusable after looking on the market I cannot find it can you give me the model of the charger adapted to Computer My computer.Chuwi GemiBook X Pro CWI574
Give me the serial number so i can ask this information and see if by chance we also have replacements.
Is still under warranty? (Less than a year ago)
This is the info i have about the charger
12V/3A wall-mounted DC tuning fork head,
outer diameter 4.0mm, inner diameter
1.7mm,
head length 10mm adapter,
Hello first of all thank you for your quick response I would like to point out that I bought your PC through Amazon less than 6 months ago the serial number is JGeBXPCY1H230301486
We have stock:
Go to you www.chuwi.com ,
Select your zone up right side(Europe/USA etcc)
Menu-Explore -Contact us- Aftersales Service
-Fill the form(is important to fill this and not write a simple email)
Write Maria, at the beginning (so my colleagues know i send you)
-Dont forget to write your Serial Number /Where are you from/When did
you buy it(warranty purpose)/Where did you buy it -
My colleagues will answer you telling what to do to get be sent a new one
They answer normally in 48/72h, if not, write me here and i will check if it went to Spam or we did not receive sometimes the serve just dont let they enter.
If possible in English language (they dont understand any other language) :
Hello i’m also searching for a new charger for my laptop Gemipro X. Do you think you an find the specific one if I send you the serial number? Thank you for your answer.
