CHUWI 2025 Hi10 X1 N150 drivers
I tried entering my serial number ( ZH10X1CN1H250502536 ) but I get an error from the website. My display is not looking right and before I return it I wanted to check it’s not a driver issue.
Thanks.
Since it’s not clear, you can upload a photo.
Where did you buy it ?
When you buy a device and it doesn’t work as it should the first time you use it, there’s only one solution: return it.
I bought it from Amazon.
It seems a bit better with the latest windows updates. It may just be i’ve not used such a low res screen for years.
Make sure you have entered the serial number exactly as shown, without spaces. If it still doesn’t work, try a different browser or contact the brand’s support directly. For the display issue, updating or reinstalling the drivers is a good first step.
Backup folder from SSD:
Drivers.zip - Google Диск
