Chuwi Corebook X Ryzen5 7430U nvme 2Tb
Is it possible to update the nvme ssd to a 2Tb unit?. I am going to upgrade but I would like to be sure before byuing the new unit.
Thanks in advance
You can check the user manual that came with the device or the Chuwi website.
I think it’s expandable up to 1 TB.
Hi bruzan2025.
Thank you for your fast answer. Yep, I checked and it says expandable up to 1Tb. But it sounds weird to me since in a 2025 notebook , if there is no any limitation in the bios or any “artificial” limit it should be ok. But to be sure if anyone has tried before :slight_smile:
I have a 2019 Corebook X i5 8259u and replaced the 512 SATA M.2 with a NvMe Crucial T500 2TB - M.2.
Thank you Jajapaja. Yep, it is working with 2TB :slight_smile:
