Hi all. I installed linux and i used it about 1 year maybe. When i install windows 11 its very low performance like edge is slow, youtube (no comment), stutter on desktop. I reinstal it serveral times and reset bios. What should i do?
Specs: Intel Celeron J4125, Intel UHD 600, 16 GB Ram, 512 SSD
Включите максимальную производительность
A J4125 is no powerhouse. And Windows 11 needs a lot of power.
Try a clean install of Windows 11 and avoid installing programs that run in the background.
Or go back to Linux and use a lightweight desktop like XFCE or possibly MATE.
You can try to clean install Windows with an automated debloating process afterwards.
I have documented this here.
I try to avoid Edge. Use Brave with additional ad blockers.
