Chuwi H10 XPro firmware
@Medo_Bamalan
this firmware is valid for tablets with these Serial numbers (includings yours)
YH10XpAB40230900001-YH10XpAB40230900500
YH10XpAB30230900001-YH10XpAB30230902000
YH10XpAB30230902001-YH10XpAB30230904500
YH10XpAB30231000001-YH10XpAB30231002500
YH10XpAB30231002501-YH10XpAB30231005000
YH10XpAB30231100501-YH10XpAB30231105000
YH10XpAB40231100001-YH10XpAB40231100500
YH10XpAB30231105001-YH10XpAB30231110000
how to:
Hello, I need the firmware of my Chuwi Hi10 XPro, my serial number is:YH10XpAB30231102641
@Mark23DF65
Gracias
JH10XpAB50240109350
Hi, I need the firmware of my Chuwi Hi10 XPro, my serial number is: JH10XpAB50240109350
Hi! What is the latest firmware for my tablet?
SN: YH10XpAB20230704849
Is the one you have, we create a different firmaware for each batch of serial numbers, but we normally wont update unless there is any problem.
ТThank you very much!
Hi, I want to request ROM for my tablet.
The SN is JH10XpAB50240101119
This one is valid for the batch Serial numbers:
JH10XpAB50240300001-JH10XpAB50240303800||
JH10XpAB50240303801-JH10XpAB50240310000||
Hi! Just got my tablet a few days ago, and I was wondering, would that firmware be the same for JH10XpAB50240106632 ? if that is the case, I see that my tablet has ROW-20240112 and the linked one is ROW-20240113. Is there any difference between them? I´m kinda hoping for better WiFi connectivity, have had some issues with it. Also, if it is the same firmware, I assume they don´t arrive via OTA? Thanks for your reply!
I checked and Yours is the same as the one posted above.
No difference probably they named different when installed.
I am currently using the SN: JH10XpAB50240306663, will the above work for me as well?
best,
Yes you can use it
Have same problem, and tablet dont turn on.
Serial JH10XpAB50240103446
Can some help me?
FDL2(142)_COM5-2024_07_30-18_54_29_849.zip (1.3 КБ)
Check this video and see if you are flashing correctly
Yes, all correct, but it stop in step “FDL2”
CWI529 s/n: HQ64G42170701994
I need to download the switchNOW.exe app.
Thank you.
