Just a concern… Hope you notice my message. I need help. My Chuwi Hi10 XPro was locked. The PIN code was changed and cannot remembered. How can I unlock my tablet? Is there a factory reset or recovery mode for Chuwi Hi10 XPro? Thank you…
No they do not have. You need to flash again the tablet. Give me your serial number and i will send you the files
Here is the serial number of my Chuwi Hi10 XPro
Serial Number: YH10XpAB30230903837
Sofware:
Flashtool
I need to reset pin too. My serial number is: ZHipXpEY00230300715.
Thanks for help.
Br, Tom
Can I use the same files and tutorial as [ErikaMae]?
