How to bypass pin lock on Chuwi Hi10 Xpro
I can’t remember the PIN for my Chuwi Hi10 Xpro tab. I can’t connect it to my pc to do a factory reset. Can you please help?
There is no reset function. You will need to reinstall the system again.
Send me your serial number
Thank you for getting back to me. Here’s my serial number;
It worked! Thank you so much!
Pls could you assist me to log into my HP10 xpro. I forgot the password and unable to access.
Are you referring to the Windows PIN? Or did you set the PIN at the device startup in the BIOS?
The PIN was reset at the device and I can’t remember the pattern.
JR
Are you referring to the Bios pin or the Windows pin?
Please help me i forgot my hi10 xpro password
Bios pin
JR
Only you can know that password, Chuwi don’t put password in the computer’s Bios.
Hi, my Chuwi Hi10 xpro is password locked.
Serial# JB10XpAB60240808150.
Do you have firmware for this?
