Send video of the problem .Are you installing the correct software?
Is this one
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.
Yours is HiPad Xpro not Hi10 Xpro
You can use the video above to install:
igris
September 14, 2024, 11:45pm
54
can send me the link,
for chuwi hi10 xpro
Sn : JH10XpAB50240305705
thanks
igris
September 22, 2024, 9:29am
57
is the firmware above compatible with chuwi hi10x pro,
OS : android 13.
SN : JH10XpAB50240305705
Hello, please tell me if you have firmware on Android 12?
Serial number YH10XpAB20230701448
igris:
JH10XpAB50240305705
yes, that is the correct files
No, that serial number only have Android 13
igris
September 30, 2024, 11:25am
61
sory for my late reply,
Okay sir, thanks.
Per7ik
October 2, 2024, 7:16am
62
Serial
yh10xpab10230503629
Per7ik
October 3, 2024, 11:21am
63
yh10xpab10230503629
Needs firmware
https://chuwi.mediafire.com/file/n8nt0hhv0bvmkox/VID_20240715_124706.mp4/file
hello this is my n.s. YH10XpAB20230702946 Which firmware should i use. since i bought it . it restart it self many time when i,m not using it. I tried factory reset but still the same. i want a try with the firmware
carlangas16:
YH10XpAB20230702946
This video is in Spanish, have not had time yet to translate but it can be easily understood.
AndChe
November 9, 2024, 4:19pm
67
Здраствуйте помогите пожалуйста с файлом прошивки
серийный номер: JH10XpAB50240102392
