I have installed Ubuntu on my Chuwi Herobook. Where can i find wifi and trackpad driver?
Thanks so much
We only have the drivers for Windows which is the system that Chuwi delivers with the device
Hej,
This worked for me on Debian 11 (HeroBook Air), you have to download the driver and then build it :
git clone https://github.com/lwfinger/rtl8723du.git
cd rtl8723du/
make all
sudo make install
On this github you can find different network cards references, for me the rtl8723du worked.
Hope that helps.
This is an EDIT because I can’t paste the orginal link of the forum where I found the solution.
My original post with the link was “flagged as spam : the community feels it is an advertisement…”
Sorry if giving working solutions is considered as “advertisement” … ![]()
