Chuwi Hi 13 Problems
Hi.
I have about 20 HI13 for my band. We use a program called Mobilsheets for the band to read music with. We bought them as Windows computer . It has been very frustrating, because windows wants to update all the time.
Now after 4 years, som of them are starting to die. Battery i blowing up so the tablet cracks open.
Do you happen to know if it is possible to get info from the “harddrive” if there is one?
An - if you should recomend a cheap android big tablet, - what should it be? Hope for some help.
Best from Mads
