Chuwi hi10 pro need a new battery
Hello Everyone
I bought a chuwi hi10 pro in 2017 november, but a few months ago(i think early’s 2019) my tablet’s battery is dead and bloat out. Then, I cant open my tablet anyway. Where can buy a new battery to replacement it?
My tablet model :
CW1529 (Hi10 HQ64G42170909057)
My battery model in below
You can buy this one https://aliexpress.ru/item/32828010859.html
Write to service@chuwi.com to indicate where to buy it since they cannot send batteries because it is prohibited.
If you do not get a satisfactory answer, comment here and I will help you find the spare part.
Well, I just saw that you already have a link. Thank you @Biosham
Thank you both of you, I sent an email to services a few hours ago. I hope they can give me a good solution. I will inform you with reply from services
Unfortunately they dont give me a satisfactory answer.Can you recommend another seller, This seller sells this battery for 12$ but cheapest shipping price is 65$ . (I am in Turkey)
@manonegra222 @Biosham
I can’t find any cheap shipping for Turkey, you can search in online shops in your country “30124135 battery”
try
У этого аккумулятора есть вилка, его можно использовать напрямую, рекомендую
https://aliexpress.ru/item/1005002277719690.html?spm=a2g0o.productlist.0.0.382f7ca1rRJUyG&algo_pvid=752a2c58-2fcf-49eb-ac68-f15c2e4c27d1&algo_exp_id=752a2c58-2fcf-49eb-ac68-f15c2e4c27d1-0
