CHUWI HI10MAX N150 touchscreen not calibrated
Hello. Chuwi Hi10Max N150 s/n ZHiMaxLZ2H251002409 touchscreen not worked.
I touch in one place - it works in another.
Where can I download the latest firmware and configuration for the touch screen?
You can download the operating system and drivers from the Chuwi website, in the “Support” and “Downloads” sections.
Check if the touchscreen flat cable is inserted properly into the connector otherwise
you probably have to replace the digitizer!
You should contact Chuwi customer support: service@chuwi.com
