please anyone help me with my Hi10Pro Tablet, after changing LCD screen (the old one was crack, and I Replace The New One), but Now It’s stuck on BIOS, I choose Android or Windows, but the same, stuck on BIOS, my serial HQ64G42180302298
WHAT SHOULD I DO???
Should I Flash BIOS? Flash Android and Windows too??
I’ve Tried To Flash Android (without flash BIOS), but it always fails at the file FASTBOOT
Delete the Chinese letters in the folder name.
sorry, but which letters do you mean?
Installation errors are usually associated with unsupported characters, most likely in the file path you have Chinese characters or other characters that intelflashtool cannot recognize.
Also try to move the firmware folder to drive C.
For exampple - this is wrong file path.
And this too.
