please is there anything i have to do to fix it?
Hi12 Q64G45160402975
The Z8300 and Z8350 processor used in the Hi12 do not appear in the list of supported processors supported for Windows 11 by Microsoft:
So does that mean i have to go for windows 10 or 8 which one did you think it will would be compatible with the Hi12 for now?
I also tried to install different driver now both the battery icon and unicam appears the only issue remained is the sound.
We dont have Windows 11 for this one, as it is quite old. ![]()
So does that mean i will only install windows 8 or windows 10?
which among is compatible with the Hi12 that’s all i want to know for now.
@manonegra222 maybe you know better
am sorry don’t be mad at me please maybe you didn’t understand my question here, i just want to know which windows would install that will work properly with the Hi12? 8 or 10
Windows 10 is perfectly compatible with the Hi12 tablet and will install without any problems, but you will need to have all the drivers for all the devices to work (WiFi, touch, sound, etc.). If the tablet is currently running Windows (any system), you must obtain a copy of the drivers, for example with doubledriver - which is a free executable available on the Internet - to install them later on the newly installed Windows 10 system.
