I can’t find the stock rom for HI8SE. Please, send links for firmware.
How can I flash this ROM? I reset my tablet and I forgot my google account to unlock it…
You need to flash it via SP Flash Tool like any other device with MTK processor.
The link above has only drivers and a flash tool, so you also need to download the firmware
Where are USB drivers for windows for this Mediatek processor? Chuwi hi8SE uses MT8735 chipset
The link with stock rom is not working . Please refresh this link or give new one .
You can download the Chuwi HI8SE Stock ROM Firmware by clicking on Download link.
After downloading the stock rom file you can also try flashing your device firmware file using SP Flash Tool. You can go through this article for the steps to flash Stock ROM using SP Flash Tool.
After search on Google, I found the realme stock rom for myself. So, I recommend you search on Google for your stock rom…
