Hipad X stock rom
Can someone please send me the stock firmware for the “HiPad X” newly released tablet?
I need it too. I have contact Chuwi customer services several times for the link to down load the firmware. But no reply from them… I think every body owned the Chuwi Hipad X should contact the Chuwi customer support and demanding for release the firmware.
Please go to Hipad X 4G Lte stock Firmware to got the firmware.
Beware that ROM fuck the video output of my tablet any way to fix?
Updated 25/07/2022
Just email service team at chuwi , I get this Hipad X Firmware Mediatek version for chuwi hipad x firmware ( mediatek )
Just flashing using sp flash tool with tablet set to off posisiton
WARNING untick preloader when you try to flash it.
Can you please back up your preloader and boot and send it to me? I mistakenly format all and now when I flash my Hipad X the device backlight only comes on. It makes noise and vibrates when I press power button on and off but there’s just no display. I can even touch the screen randomly and it will react.
@lowlo
@DmonR
Did you manage to find stock boot.bin and preloader.bin or fix your hipad x in any other way? Mine is doing the exact same thing with display after flashing above rom
No. My HiPad X is broken now. The screen stopped working. I wasn’t going to go pay to fix that.
Apparently this issue is specific to mediatek devices according to this post
Caused by flashing a rom for the correct device but incorrect variant resulting in a fully functioning device but with certian incompatibilities in our case with the display.
This is promising news since it means the possibility of restoring the device is there just certain modules need to be reflashed over the current broken rom.
Its unfortunate that Chuwi cannot just make available the correct stock rom for this variant of Hipad X. The only stock rom found on the internet doesnt exactly work out of the box for the average user and has to be flashed with the know-how of disabling certain modules before flashing.
This is leaving a lot of users that want to unlock it’s full potential by rooting with an unusable and irrepairable device unnessecarily. We are literally 1 click away from restoring our devices if we had just the correct files.
This needs to happen some of us have only this 1 device and depend on it for doing bussiness.
I have emailed chuwi and posted on xda and will share the files here if I do manage to find them.
@kecapjeruknipis
How did you know not to flash preloader?
Is there any way you can share your preloader file?
Chuwi wants the tablet to be sent to Hong Kong for repair but it will cost me the same as 2 new tablets…
Hi, wich ROM with security up to date can I install on my HipadX ?
And wich file can I use if I want to rollback with stock rom ?
Thank you … Chuwi… Never again…
Send me your serial number so i can send you the files
HiPadXQ128G210504707
Is it stock ROM or a rom with security update ?
No, its the original files of the tablet. We dont have a new uptade as is already discontinue
what a bullshit, 2 years of usage and ready for trash… My security apps doesnt works with since few month… First and last chuwi device.
Yoh help broh this is chuwi hipad x model cwi520 need firmware
You’re asking a user who is: not active: ChuwiESnotactive, who isn’t going to answer you.
You can download the operating system and drivers from the Chuwi website, in the “Support” and “Downloads” sections.
or
You should contact Chuwi customer support: service@chuwi.com
