I need stock firmware for Chuwi Hipad X 4G Lte. Thanks
I need that too. It would be awesome if they put the bsp on github
I need it too. pls provide for us
I got the link from AMAZON seller give me the link:
After download and un-zip it I see the folder name is “MT8788_OCH2_T4L2X2” remove all Chinese character on the folder name( do not down load Brush tools and drivers plus tutorial folder, it is old and its splash tool does not work) I use SP_Flash_Tool_v5.2032_Win to load firmware without any error . But look in side this folder firmware I see “MT6771_Android_scatter.txt” this firmware is for MT6771 which is chip on HiPad X. I give away my tablet already, So if any one use this firmware please confirm it is for Chuwi Hipad X? and it is global rom or Chinees rom?
Google it, I found out the MT6771/MT8788 P60 is same platform.
its global, says on the filename (those chinese characters)
THX bro
appreciate it
Do you confirm the firmware for CHUWI HIPAD X? I gave away my tablet, I may consider to get it again. Thanks
