Hey, I have this problem: My Chuwi HiPad Max keeps restarting, and I can’t stop it from doing so.
How can I fix this.
Thank you so much in advance.
How can I fix this.
Разбираем чистим кулер и меняем высохшую термопасту.
It is due to an update in Google .
Check this. Try the solution said by an user on April 16
If not reinstall the system according to your serial number also on April 16
And in theory you should receive an update automatic of the system that repairs this error.
