Dear Chuwi …
I have a Chuwi Minibook 8100y with 8gb ram … 128ssd + 500micro sd + 1 tb ssd, working fine but
memory is low …
How can i expand from 8 to 16 gb ??
And what ram should i use ?
Thank you
Wim
Dear Chuwi …
memory is low …
Thank you
Wim
I believe that ram soldered to the motherboard it is non expandable, like on other laptops from chuwi.
OK that is very bad … IF the ram module fails, the notebook fails … thats not normal
BUT … i will do my trick with enlarging the emp file pagesys file
With an SSD windows thinks its ram and work fine
