Can someone please tell me:
- Is Transcend 32Gb 1 X 32Gb Ddr4 3200Mhz Sodimm System Memory compatible with the CHUWI RZBOX AMD RYZEN 9 4900H | Windows 10 | DDR 16GB+SSD 512GB.
- Is WD Blue SN550 1TB NVME M.2 2280 PCIe Gen3 SSD is compatible with the CHUWI RZBOX AMD RYZEN 9 4900H
- Can you mix a 16gb of ram module with a 32gb module or do they need to be of the same value?
