Hello. I’m using Tablet PC, all is right, but bought it without stylus. Now I want to buy stylus, but i don’t like AAAA battery in H7 version. Will HiPen H6 work with my tablet if I will buy it instead? Will it work like HiPen H7 or they are diffenet and HiPen H7 is better?
Thanks!
Hello
HiPen H6 will work fine as well. Or you can go for other third-party pens you can find in Amazon that are compatible to Surface.They also should work.
