Hi, I would like to order a 128gb sd card for Hi10x.
I am worried some sd card may not be compatible with the tablet.
What brand and model are you using? Any recommendation? thanks
Hi, I have been using the 128G bytes SD card in the NTFS format.
The Hi10x is mounting it as a d: drive.
I have been using it without any problems.
I think that it is the same as SanDisk microSDXC ULTRA 128GB SDSQUNS-128G.
Sorry, this SD card was a gift, so I searched for a product that looked the same.
The model name is for your reference.
